Api session event answer upgrade zoning permit denied
Revision as of 12:07, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/answer/upgrade_zoning_permit_denied/
Description: Stakeholder's upgrade is denied based on zoning
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (BUILDING Integer ID) Building ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/upgrade_zoning_permit_denied/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/upgrade_zoning_permit_denied/", options)
