Api session event answer building demolish approval
Revision as of 12:07, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/answer/building_demolish_approval/
Description: Stakeholder approves demolition of Building
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (BUILDING Integer ID) Building ID
2 REQUIRED (true, false) Approves true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/building_demolish_approval/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/answer/building_demolish_approval/", options)
