Api session event answer building ask demolish date
Revision as of 12:07, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/answer/building_ask_demolish_date/
Description: Stakeholder has planned the demolition of a particular Building for a particular date stored in a Popup
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder ID
1 REQUIRED (BUILDING Integer ID) Building ID
2 REQUIRED (POPUP Integer ID) Popup ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/answer/building_ask_demolish_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/answer/building_ask_demolish_date/", options)
