Api session event editor trigger set method
API Endpoint: api/session/event/editortrigger/set_method/
Description: Set Method
0 REQUIRED (TRIGGER Integer ID or multiple values in array [1, 2, 3]) Triggers
1 REQUIRED (Method or multiple values in array [a, b, c]) Method[]
204 No Content
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_method/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "GET" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editortrigger/set_method/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "GET", "POST", "POST" ] ]'
JavaScript example POST
 body: '[ 1, "GET" ]'
fetch("https://engine.tygron.com/api/session/event/editortrigger/set_method/", options)
