Api session event editor stakeholder transfer ownership
Revision as of 12:06, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorstakeholder/transfer_ownership/
Description: Transfer Ownership
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
2 REQUIRED (true, false) Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/transfer_ownership/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/transfer_ownership/", options)
