Api session event editor sound add
Revision as of 12:06, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editorsound/add/
Description: Add new Sound
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorsound/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorsound/add/", options)
