Api session event editor overlay set show difference
API Endpoint: api/session/event/editoroverlay/set_show_difference/
Description: Set whether a specified Grid Overlay has a difference option. If an Overlay has a difference option, an addition output is available computed from the difference between the CURRENT and MAQUETTE outputs.
0 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay ID (must relate to a Grid Overlay)
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Has a difference option (false means there is no difference option for this Overlay)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_show_difference/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_show_difference/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ] ]'
JavaScript example POST
 body: '[ 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_show_difference/", options)
