Api session event editor overlay set service source
Revision as of 12:05, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editoroverlay/set_service_source/
Description: Set the Service Source for a specified Service Overlay.
0 REQUIRED (OVERLAY Integer ID) Service Overlay ID
1 REQUIRED (SOURCE Integer ID) Source ID
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_service_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_service_source/", options)
