Api session event editor overlay set overlay source
API Endpoint: api/session/event/editoroverlay/set_overlay_source/
Description: Add or remove specified Sources to or from a specified Source Overlay. Unincluded Sources which are already related to the Overlay will remain related. Unincluded Sources which are not related to the Overlay will remain unrelated.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a Sources Overlay)
1 REQUIRED (SOURCE Integer ID or multiple values in array [1, 2, 3]) Array of Source IDs
2 REQUIRED (true, false) Should be added to the Overlay (false removes the Sources from the Overlay) true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ], true ]'
JavaScript example POST
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/", options)
