Api session event editor netcluster generate clusters
API Endpoint: api/session/event/editornetcluster/generate_clusters/
Description: Generate Clusters
0 REQUIRED (NetType or multiple values in array [a, b, c]) Net Type[]
1 REQUIRED (Enumeration) ClusteringType ADD_TO_EXISTING_FOR_BUILDINGS, MAP_SECTORS, PER_ATTRIBUTE, PER_BUILDING, PER_LOAD or PER_LOAD_UNIQUE_OWNER
2 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
4 REQUIRED (Floating point number) Double
5 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
6 REQUIRED (String) String
7 REQUIRED (true, false) Boolean true or false
8 OPTIONAL (Floating point number) Double
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetcluster/generate_clusters/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ "ELECTRICITY", "PER_LOAD", {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, 1, 62, 1, "Text", true ]
Curl example multi item POST
[ [ "ELECTRICITY", "GAS", "HEAT" ], "PER_LOAD", {
}, [ 1, 2, 3 ], 91, 1, "Text", true ]
JavaScript example POST
 body: '[ "ELECTRICITY", "PER_LOAD", { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, 1, 62, 1, "Text", true ]'
fetch("https://engine.tygron.com/api/session/event/editornetcluster/generate_clusters/?crs=3857", options)
