Api session event editor measure remove levee
API Endpoint: api/session/event/editormeasure/remove_levee/
Description: Remove specified Levee Spatials from a Measure.
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Levee Spatial IDs
204 No Content
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_levee/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1 ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/remove_levee/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, [ 1, 2, 3 ] ]'
JavaScript example POST
 body: '[ 1, 1 ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/remove_levee/", options)
