Api session event editor measure add upgrade
API Endpoint: api/session/event/editormeasure/add_upgrade/
Description: Add a new Upgrade Spatial to a Measure.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID |
| 200 | Integer (Upgrade Spatial ID) |
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_upgrade/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_upgrade/", options)
