Api session event editor measure add event
API Endpoint: api/session/event/editormeasure/add_event/
Description: Add a new event to a Measure for a specific Action Type.
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Server Side (false = Client Side)
2 REQUIRED (ActionType or multiple values in array [a, b, c]) Action Type
200 Integer[] (Coded Event ID)
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, true, "CONSTRUCTION_PLAN" ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editormeasure/add_event/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN_CANCEL" ] ]'
JavaScript example POST
 body: '[ 1, true, "CONSTRUCTION_PLAN" ]'
fetch("https://engine.tygron.com/api/session/event/editormeasure/add_event/", options)
