Api session event editor geolink set additional
API Endpoint: api/session/event/editorgeolink/set_additional/
Description: Inject additional Attributes into the created feature.
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) CustomGeo Link IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_additional/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name 1", [ 1.0, 2.0 ] ]'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeolink/set_additional/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ] ]'
JavaScript example POST
 body: '[ 1, "Attribute Name 1", [ 1.0, 2.0 ] ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/set_additional/", options)
