Api session event editor geolink add
API Endpoint: api/session/event/editorgeolink/add/
Description: Add new Geo Link
| 0 | REQUIRED | (GeoLinkType or multiple values in array [a, b, c]) | Geo LinkType[] | |
curl 'https://engine.tygron.com/api/session/event/editorgeolink/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "AREA", "Text 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorgeolink/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ "AREA", "BUILDING", "ROAD" ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript example POST
body: '[ "AREA", "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorgeolink/add/", options)
