Api session event editor building add section
API Endpoint: api/session/event/editorbuilding/add_section/
Description: Add Section
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Buildings
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_section/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'
Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_section/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'
JavaScript example POST
 body: '1'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_section/", options)
