Api session event editor building add polygons
API Endpoint: api/session/event/editorbuilding/add_polygons/
Description: Add Polygons for Building Section. In case the Building is empty, optionally set ownership to largest Plot Owner of provided MultiPolygon
| 0 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building ID | |
| 1 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Section ID | |
| 2 | REQUIRED | (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) | MultiPolygon | |
| 3 | REQUIRED | (true, false) | Use largest Owner | true or false |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add_polygons/?crs=3857' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '
[ 1, 1, {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]
}, false ]
'Curl example multi item POST
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ {
"coordinates" : [ [ [ [ 658646.762, 6799451.896 ], [ 658646.762, 6799461.896 ], [ 658656.762, 6799461.896 ], [ 658656.762, 6799451.896 ], [ 658646.762, 6799451.896 ] ] ] ]
"coordinates" : [ [ [ [ 658656.762, 6799451.896 ], [ 658656.762, 6799461.896 ], [ 658666.762, 6799461.896 ], [ 658666.762, 6799451.896 ], [ 658656.762, 6799451.896 ] ] ] ]
} ], false ]
'JavaScript example POST
body: '[ 1, 1, { "type" : "MultiPolygon", "coordinates" : [ [ [ [ 658636.762, 6799451.896 ], [ 658636.762, 6799461.896 ], [ 658646.762, 6799461.896 ], [ 658646.762, 6799451.896 ], [ 658636.762, 6799451.896 ] ] ] ]}, false ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add_polygons/?crs=3857", options)
