Api session event editor building add
API Endpoint: api/session/event/editorbuilding/add/
Description: Add new Building
| 0 | REQUIRED | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Stakeholders | |
| 1 | REQUIRED | (FUNCTION Integer ID or multiple values in array [1, 2, 3]) | Functions | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | String[] |
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "Text 1" ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorbuilding/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]'JavaScript example POST
body: '[ 1, 1, "Text 1" ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/add/", options)
