Api session event editor attributeaction remove
API Endpoint: api/session/event/editorattributeaction/remove/
Description: Remove existing Attribute Action
| 0 | REQUIRED | (ATTRIBUTE_ACTION Integer ID or multiple values in array [1, 2, 3]) | Attribute Actions |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '1'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editorattributeaction/remove/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 2, 3 ]'JavaScript example POST
body: '1'
fetch("https://engine.tygron.com/api/session/event/editorattributeaction/remove/", options)
