How to start the editor with an Empty Project
Template:Game reference
This article may contain references or images in the style of the old Tygron Platform.
In some situations it might be desired to generate a 3D world that is not based on real data. For instance when a game needs to be created around a fictional area, or when a game only needs to be created to quickly place and view a construction. In such a case it is possible to select in the wizard the option to generate a game not based on real data. The result will be a 3D world without any constructions or terrain behavior. These will need to be added manually, in the editor.
How to generate a game not based on real data:
  1. Log in to the online Tygron Engine
  2. Select "Start Editor" from the main menu Editor section
  3. Select "New Project"
  4. Name the project as desired
  5. Select localization settings and continue
  6. Select the option "No" when asked to use real data and continue
  7. Set the size of the area to be generated and continue
  8. Add more stakeholders if desired from the drop down menu and continue
  9. Add at least one indicator and continue
  10. Couple indicator(s) and stakeholder(s)
  11. Confirm all selections and continue
  12. Notice an empty 3D world is generated
