Api session event editor update with id
API Endpoint: api/session/event/editor/update_with_id/
Description: Waits for update of all active Overlays, Indicators, Panels and Triggers with unique ID. Note: for long-running updates use: set_scheduled_update/ to schedule an update.
| 0 | REQUIRED | (true, false) | Reset all X-Queries | true or false |
| 1 | REQUIRED | (Integer number) | Unique Update ID to prevent multiple updates |
| 200 | Boolean (Content was updated) |
curl 'https://engine.tygron.com/api/session/event/editor/update_with_id/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ true, 78 ]'Curl example multi item POST
curl 'https://engine.tygron.com/api/session/event/editor/update_with_id/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ true, 30 ]'JavaScript example POST
body: '[ true, 78 ]'
fetch("https://engine.tygron.com/api/session/event/editor/update_with_id/", options)
