Api session event editor update
Revision as of 12:01, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editor/update/
Description: Calculate all active Overlays, Indicators, Panels and Triggers and wait for the update. Note: for long-running calculations use: set_scheduled_update/ to schedule an update.
0 OPTIONAL (true, false) Reset all X-Queries (optional)
200 Boolean (Content was updated)
curl 'https://engine.tygron.com/api/session/event/editor/update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editor/update/", options)
