Api session event editor set scheduled update
Revision as of 12:01, 15 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: api/session/event/editor/set_scheduled_update/
Description: Schedule a long-running update of all active Overlays, Indicators, Panels and Triggers.
0 OPTIONAL (Integer number) Scheduled Time in milliseconds since epoch 1970. Note: use 0 for direct execution or -1 to cancel
1 OPTIONAL (String) Send Email to this Address when finished (optional)
2 OPTIONAL (String) Send SMS to this number when finished (optional)
204 No Content
curl 'https://engine.tygron.com/api/session/event/editor/set_scheduled_update/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST
 body: ''
fetch("https://engine.tygron.com/api/session/event/editor/set_scheduled_update/", options)
