Api session 3dtiles
API Endpoint: api/session/3dtiles
GET layer.json
API Endpoint: web/3dtiles/layer.json
Produces: application/json
Parameters: None
Examples
GET {z}/{x}/{y}.terrain
API Endpoint: web/3dtiles/{z}/{x}/{y}.terrain
Produces: application/vnd.quantized-mesh
Parameters:
| Name | Location | Type | Default value |
| z | Path | Integer | |
| x | Path | Integer | |
| y | Path | Integer | |
| v | Query | String |
Examples
GET Textures/{path}
API Endpoint: web/3dtiles/Textures/{path}
Produces: image/png, image/jpeg
Parameters:
| path | Path | String |
Examples
GET tileset.json
API Endpoint: web/3dtiles/tileset.json
Parameters:
| webStakeholderID | Header | Integer | |
| style | Query | WebModelStyle | WHITE |
| maptype | Query | Map Type | MAQUETTE |
| texture | Query | TextureSize | MEDIUM |
| spacing | Query | double | 2.0 |
| bbox | Query | String | |
| crs | Query | String | LOCAL |
Examples
Basic endpoint:
https://engine.tygron.com/web/3dtiles/tileset.json?token=WEB_TOKEN3D Tiles:
Query for MapType: CURRENT:
https://engine.tygron.com/web/3dtiles/tileset.json?maptype=CURRENT&token=WEB_TOKEN3D Tiles:
Model Style: WHITE:
https://engine.tygron.com/web/3dtiles/tileset.json?style=WHITE&token=WEB_TOKEN3D Tiles:
Model Style: COLORED:
https://engine.tygron.com/web/3dtiles/tileset.json?style=COLORED&token=WEB_TOKEN3D Tiles:
Texture Size (smaller reduces memory): SMALL:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=SMALL&token=WEB_TOKEN3D Tiles:
Texture Size (smaller reduces memory): MEDIUM:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=MEDIUM&token=WEB_TOKEN3D Tiles:
Texture Size (smaller reduces memory): LARGE:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=LARGE&token=WEB_TOKEN3D Tiles:
Model Spacing (larger means e.g. trees further apart): 1.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=1.0&token=WEB_TOKEN3D Tiles:
Model Spacing (larger means e.g. trees further apart): 2.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=2.0&token=WEB_TOKEN3D Tiles:
Model Spacing (larger means e.g. trees further apart): 4.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=4.0&token=WEB_TOKEN3D Tiles:
GET {id}.gltf
API Endpoint: web/3dtiles/{id}.gltf
Parameters:
| id | Path | Integer | |
| custom | Query | boolean | false |
| detail | Query | boolean | false |
