Api session items modeldatas
Revision as of 14:18, 12 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/modeldatas/
Default Query:
https://engine.tygron.com/api/session/items/modeldatas/?f=JSON&token=API_TOKEN
Example Response:
  "additions" : [ ],
  "animMultiplier" : null,
  "buffer" : 10,
  "dimension" : 1,
  "frequency" : 10,
  "id" : 0,
  "instanceColor" : "GRAY",
  "isAlpha" : false,
  "isShowCloseby" : false,
  "modelHeight" : 6.30242,
  "modelWidth" : 1.6587989,
  "name" : "traffic_light",
  "particleEmitters" : [ ],
  "placement" : "POINT",
  "randomScale" : 0.0,
  "roots" : false,
  "rotation" : "FREE",
  "show" : "MIDDLE",
  "variation" : 1,
  "version" : 1
  "additions" : [ ],
  "buffer" : 10,
  "dimension" : 1,
  "frequency" : 10,
  "id" : 1,
  "isAlpha" : false,
  "modelHeight" : 1.25364,
  "modelWidth" : 1.039926,
  "name" : "house_chimney",
  "roots" : false,
  "rotation" : "FIXED",
  "show" : "MIDDLE",
  "variation" : 1,
  "version" : 2
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/modeldatas/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/modeldatas/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/modeldatas/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/modeldatas/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/modeldatas/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/modeldatas/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/modeldatas/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/modeldatas/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/modeldatas/?f=ZIPSMILE&token=API_TOKEN
Api Model Addition
API Model description of Addition
Name Type Description
amount int
animMultiplier double
name String
randomScale double
show Show
Api Model InstanceColor
API Enumeration description of InstanceColor
Name Description
GRAY
WHITE
VEGIE_GREEN
GRAIN_YELLOW
FLOWERS
Api Model ModelData
API Model description of ModelData
additions Addition[]
buffer int
dimension int
frequency int
id int
instanceColor InstanceColor
isAlpha boolean
isShowCloseby boolean
modelHeight double
modelWidth double
name String
particleEmitters ParticleEmitterCoordinatePair[] Particle EmitterCoordinatePair[]
placement Placement
randomScale double
roots boolean
rotation Rotation
show Show
variation int
version int
Api Model ParticleEmitterCoordinatePair
API Model description of ParticleEmitterCoordinatePair
id int
offsetCoordinate double[]
particleEmitterID int Particle Emitter ID
Api Model Placement
API Enumeration description of Placement
Name Description
POINT
EDGE
Api Model Rotation
API Enumeration description of Rotation
Name Description
FIXED
QUARTER
FREE
Api Model Show
API Enumeration description of Show
Name Description
FAR
MIDDLE
CLOSE
