Web 3dtiles Endpoint
General path: web/3dtiles/
QM
getQMLayer
Path: web/3dtiles/layer.json
Type: GET
Produces: application/json
Parameters: None
getQuantizedMesh
Path: web/3dtiles/{z}/{x}/{y}.terrain
Type: GET
Produces: application/vnd.quantized-mesh
Parameters:
Name Location Type Default value
z Path Integer
x Path Integer
y Path Integer
v Query String
Tiles3D
getTile
Path: web/3dtiles/{id}.gltf
Type: GET
Parameters:
style Query WebModelStyle WHITE
maptype Query Map Type MAQUETTE
id Path Integer
custom Query boolean false
detail Query boolean false
texture Query TextureSize MEDIUM
spacing Query double 2.0
getAssets
Path: web/3dtiles/Textures/{path : [a-zA-Z0-9/._-]+}
Type: GET
Produces: image/png , image/jpeg
Parameters:
path Path String
getTileset
Path: web/3dtiles/tileset.json
Type: GET
Parameters:
webStakeholderID Header Integer
bbox Query String
crs Query String LOCAL
GET Examples: Basic endpoint:
https://engine.tygron.com/web/3dtiles/tileset.json?token=WEB_TOKEN
Basic endpoint:
Query for MapType: CURRENT:
https://engine.tygron.com/web/3dtiles/tileset.json?maptype=CURRENT&token=WEB_TOKEN
Model Style: WHITE:
https://engine.tygron.com/web/3dtiles/tileset.json?style=WHITE&token=WEB_TOKEN
Model Style: WHITE:
Model Style: COLORED:
https://engine.tygron.com/web/3dtiles/tileset.json?style=COLORED&token=WEB_TOKEN
Texture Size (smaller reduces memory): SMALL:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=SMALL&token=WEB_TOKEN
Texture Size (smaller reduces memory): MEDIUM:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=MEDIUM&token=WEB_TOKEN
Texture Size (smaller reduces memory): LARGE:
https://engine.tygron.com/web/3dtiles/tileset.json?texture=LARGE&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 1.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=1.0&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 2.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=2.0&token=WEB_TOKEN
Model Spacing (larger means e.g. trees further apart): 4.0:
https://engine.tygron.com/web/3dtiles/tileset.json?spacing=4.0&token=WEB_TOKEN
