Api session items sounds
Revision as of 09:14, 10 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/sounds/
Edit items with events described at Api session event editor sound.
Default Query:
https://engine.tygron.com/api/session/items/sounds/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/sounds/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/sounds/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/sounds/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/sounds/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/sounds/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/sounds/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/sounds/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/sounds/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/sounds/?f=ZIPSMILE&token=API_TOKEN
Api Model Sound
API Model description of Sound
Name Type Description
background boolean
filename String
id int
loop boolean
name String
version int
volume double
