Api session items customgeometries
Revision as of 09:14, 10 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/customgeometries/
Edit items with events described at Api session event editor customgeometry.
Default Query:
https://engine.tygron.com/api/session/items/customgeometries/?f=JSON&token=API_TOKEN
Example Response:
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/customgeometries/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/customgeometries/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/customgeometries/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/customgeometries/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/customgeometries/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/customgeometries/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/customgeometries/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/customgeometries/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/customgeometries/?f=ZIPSMILE&token=API_TOKEN
Api Model CustomGeometry
API Model description of CustomGeometry
Name Type Description
absoluteHeight boolean
backFaceCulling boolean
color TColor Color
data float[]
id int
texture String
version int
Api Model TColor
API Model description of TColor
