How to verify available data in a Project Map
When a new project has been generated, the Query Tool can quickly check if the area contains data that can be retrieved by a Query. Doing so enables the user to quickly check the available data, without having to create a separate Excel Indicator spreadsheet with queries.
For instance, when a project map has been created with a safe zone terrain, by importing a relevant feature service from ArcGIS Online, the query tool can quickly verify if the safe zone data can be retrieved with a Query.
How to verify available data in a project map with an ArcGIS safe zone:
  1. Load or create a project with an ArcGIS safe zone
  2. Select Editor → Tools → Query Tool
  3. Select FLOORSIZE as Result Parameter
  4. Add TERRAINTYPE IS SAFE_ZONE as clause
  5. Verify that the Query result returns a value
Verify data in project area
