Videocard Troubles
Revision as of 07:39, 9 June 2026 by Frank@tygron.nl (talk | contribs)
Issues related to videocards.
Drivers
Please make sure you have the latest drivers installed for your video card from the orginal manufactor. Below a list of videocard driver download locations:
Two Videocards
In case your system has a dual video card setup, follow How to activate the correct videocard.
USB Port
When you are using a USB port to, for instance, connect a docking station, large screen or another external screen, you might encounter hardware issues because the Tygron Client cannot recognize your video card appropriately.
The workaround for this to first start the Tygron Client and then connect the USB-port.
