Install
Revision as of 07:39, 9 June 2026 by Frank@tygron.nl (talk | contribs)
Preview installer download.
The Tygron Client is an application that allows users to connect with the Tygron Engine. It needs to be installed on a local machine. The installer guides users through this process, ensuring easy setup. It can be downloaded from https://engine.tygron.com.
Once the installer has completed you can launch the Tygron Client. See the following page to learn how to log in.
If you encounter any problems, please view the requirements for the Tygron Client first.
Installation parameters
When necessary, the installer also provides options to help automate or script the installation process. The installer can be run from the command line as follows to obtain a list of available flags:
./TygronClient-Win64.exe -c -h
This allows for a silent/unattended install as well, with the followng parameters:
./TygronClient-Win64.exe -q o
