Api session items cinematicdatas
API Endpoint: /api/session/items/cinematicdatas/
Edit items with events described at Api session event editor cinematic.
Default Query:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=JSON&token=API_TOKEN
Example Response:
  "active" : false,
  "animateToStart" : false,
  "animateToStartPoint" : false,
  "endType" : "SIMPLE",
  "id" : 0,
  "keyIndex" : 0,
  "keyPoints" : [ {
    "description" : "Welcome to Api-test, first a flytrough to make you familiar with the area.",
    "direction" : {
      "x" : 285.356,
      "y" : 51.329113786870785,
      "z" : 285.356
    "eventBundlesIDs" : [ ],
    "id" : 7,
    "location" : {
      "x" : 426.777,
      "y" : 148.56966681707473,
      "z" : 426.777
    "pause" : true,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "description" : "",
    "direction" : {
      "x" : 300.0,
      "y" : 55.20368105299929,
      "z" : 250.0
    "id" : 6,
    "location" : {
      "x" : 500.0,
      "y" : 144.91636178848591,
      "z" : 250.0
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "description" : "",
    "direction" : {
      "x" : 285.356,
      "y" : 56.87688383945199,
      "z" : 214.644
    "id" : 5,
    "location" : {
      "x" : 426.777,
      "y" : 151.54411246559837,
      "z" : 73.223
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "description" : "You are now entering the neighborhood Klarenbeek.",
    "direction" : {
      "x" : 250.0,
      "y" : 49.06819152832031,
      "z" : 200.0
    "id" : 4,
    "location" : {
      "x" : 250.0,
      "y" : 157.1198216847011,
      "z" : 0.0
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "description" : "You are now entering the neighborhood Sonsbeek-Noord.",
    "direction" : {
      "x" : 214.644,
      "y" : 43.67911892845517,
      "z" : 214.644
    "id" : 3,
    "location" : {
      "x" : 73.223,
      "y" : 146.51884792162025,
      "z" : 73.223
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "description" : "You are now entering the neighborhood Hazegrietje.",
    "direction" : {
      "x" : 200.0,
      "y" : 42.794297238613694,
      "z" : 250.0
    "id" : 2,
    "location" : {
      "x" : 0.0,
      "y" : 151.31980790483192,
      "z" : 250.0
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "direction" : {
      "x" : 214.644,
      "y" : 44.550744256307915,
      "z" : 285.356
    "id" : 1,
    "location" : {
      "x" : 73.223,
      "y" : 136.94186375357887,
      "z" : 426.777
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "description" : "You are now entering the neighborhood Onder de Linden.",
    "direction" : {
      "x" : 250.0,
      "y" : 51.85581020598716,
      "z" : 300.0
    "id" : 0,
    "location" : {
      "x" : 250.0,
      "y" : 146.50577267733487,
      "z" : 500.0
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
    "description" : "",
    "direction" : {
      "x" : 250.0,
      "y" : 50.98006374277967,
      "z" : 250.0
    "id" : 8,
    "location" : {
      "x" : 250.0,
      "y" : 603.5534057617188,
      "z" : 251.0
    "pause" : false,
    "soundID" : -1,
    "time" : 4.0,
    "up" : {
      "x" : 0.0,
      "y" : 1.0,
      "z" : 0.0
  "name" : "Welcome Cinematic",
  "stakeholderID" : -1,
  "version" : 1,
  "voice" : ""
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/cinematicdatas/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/cinematicdatas/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/cinematicdatas/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/cinematicdatas/?f=ZIPSMILE&token=API_TOKEN
Api Model CinematicData
API Model description of CinematicData
Name Type Description
active boolean
animateToStart boolean
animateToStartPoint boolean
endType EndType
id int
keyIndex int
keyPoints KeyPoint[] KeyPoint[]
localClientOnly boolean
name String
stakeholderID int
version int
voice String
Api Model EndType
API Enumeration description of EndType
Name Description
SIMPLE
LOOP
WAIT_AT_END
Api Model KeyPoint
API Model description of KeyPoint
description String
direction Vector3d
eventBundlesIDs int[]
id int
location Vector3d
pause boolean
soundID int
time double
up Vector3d
Api Model Vector3d
API Model description of Vector3d
x double
y double
z double
