Api session items popups
API Endpoint: /api/session/items/popups/
Default Query:
https://engine.tygron.com/api/session/items/popups/?f=JSON&token=API_TOKENExample Response:
"answers" : [ ],
"calendar" : null,
"color" : {
"argb" : -6704129
"id" : 0,
"imageType" : "RECEIVE_REQUEST",
"linkID" : 1,
"linkType" : "PANELS",
"modelDataID" : -1,
"modelType" : "DECLINED",
"name" : " 1",
"opensAutomatically" : false,
"overrideAttention" : true,
"point" : {
"type" : "Point",
"coordinates" : [ 658907.9990757483, 6798948.801026824, 36.557 ]
"polygons" : null,
"scale" : 1.0,
"text" : "",
"title" : "Text Panel",
"type" : "INTERACTION",
"version" : 3,
"visibleForStakeholderIDs" : [ 0, 1, 2, 3, 4, 5 ],
"visibleTimeframe" : 0
"answers" : [ ],
"calendar" : null,
"color" : {
"argb" : -19610
"id" : 1,
"linkID" : 2,
"modelDataID" : -1,
"modelType" : "ELEVATION",
"name" : " 2",
"point" : {
"type" : "Point",
"coordinates" : [ 659100.8960954784, 6799034.555303296, 80.804 ]
"polygons" : null,
"scale" : 1.0,
"text" : "",
"title" : "Text Panel (2)",
"version" : 6,
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/popups/?version=100&token=API_TOKENPseudo-Mercator:
https://engine.tygron.com/api/session/items/popups/?crs=3857&token=API_TOKENDegrees:
https://engine.tygron.com/api/session/items/popups/?crs=4326&token=API_TOKENAmersfoort / RD New:
https://engine.tygron.com/api/session/items/popups/?crs=28992&token=API_TOKENLocal Coordinates:
https://engine.tygron.com/api/session/items/popups/?crs=LOCAL&token=API_TOKENbbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/popups/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFOO:
https://engine.tygron.com/api/session/items/popups-foo/?crs=3857&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/popups/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/popups/size/?token=API_TOKENPopups (GeoJSON):
https://engine.tygron.com/web/popups.geojson?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/popups/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/popups/?f=JSON&token=API_TOKENGEOJSON:
https://engine.tygron.com/api/session/items/popups/?f=GEOJSON&token=API_TOKENGPKG:
https://engine.tygron.com/api/session/items/popups/?f=GPKG&token=API_TOKENDXF:
https://engine.tygron.com/api/session/items/popups/?f=DXF&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/popups/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/popups/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/popups/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/popups/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/popups/?f=ZIPSMILE&token=API_TOKENApi Model Answer
API Model description of Answer
| Name | Type | Description |
| clientEvents | CodedEvent[] | |
| contents | String | |
| events | CodedEvent[] | |
| id | int | |
| selected | boolean |
Api Model CodedEvent
API Model description of CodedEvent
| id | int | |
| parameters | Object[] |
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
| type | String | [[#Api Model MultiPolygon|MultiPolygon]] |
| coordinates | double[][][][] | array of [[#Api Model Polygon|Polygon]]s; [[#Api Model Polygon|Polygon]] is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z] |
Api Model Point
API Model description of Point
| type | String | [[#Api Model Point|Point]] |
| coordinates | double[] | x, y, (optional) z |
Api Model PopupData
API Model description of PopupData
| answers | Answer[] | Answer (Panel)[] |
| calendar | long | |
| color | TColor | Color |
| id | int | |
| imageType | PopupImageType | PopupImageType |
| linkID | int | |
| linkType | MapLink | Maplink |
| modelDataID | int | [[Model Data]] ID |
| modelType | PopupModelType | PopupModelType |
| name | String | |
| opensAutomatically | boolean | |
| overrideAttention | Boolean | |
| point | Point | Point |
| polygons | MultiPolygon | MultiPolygon |
| scale | double | |
| text | String | |
| title | String | |
| type | Type | |
| version | int | |
| visibleForStakeholderIDs | int[] | [[Stakeholder]]s ID |
| visibleTimeframe | int |
Api Model PopupImageType
API Enumeration description of PopupImageType
| Name | Description |
| PICK_DATE | |
| REQUEST_PERMIT | |
| RECEIVE_REQUEST | |
| WAITING | |
| DECLINE | |
| APPROVE | |
| WAIT_BUILD | |
| WAIT_DEMOLISH | |
| BUILD_PROGRESS | |
| DEMOLISH_PROGRESS | |
| BUY_LAND | |
| SELL_LAND |
Api Model PopupModelType
API Enumeration description of PopupModelType
| APPROVED | |
| ARROW | |
| BUY | |
| CONNECT_ON | |
| CONNECT_OFF | |
| CONSTRUCTING | |
| ELEVATION | |
| DECLINED | |
| DEMOLISHING | |
| WAITING | |
| QUESTION_MARK | |
| TRAFFIC_NOISE | |
| WATER_CRANE | |
| WATER_ARROW | |
| WATER_WEIR | |
| LIGHT_BULB | |
| LIGHTNING | |
| BAR_CHART | |
| EXCLAMATION |
Api Model TColor
API Model description of TColor
Api Model Type (PopupData)
API Enumeration description of Type
| STAKEHOLDER_STANDARD | |
| INTERACTION | |
| INTERACTION_WITH_DATE | |
| INFORMATION | |
| LABEL |
