Api session items neuralnetworks
API Endpoint: /api/session/items/neuralnetworks/
Edit items with events described at Api session event editor neuralnetwork.
Default Query:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=JSON&token=API_TOKENExample Response:
"attributes" : {
"BOX_OVERLAP" : [ 1.0 ],
"INFERENCE_MODE" : [ 1.0 ],
"MASK_THRESHOLD" : [ 0.9 ],
"MAX_CELL_SIZE_M" : [ 0.25 ],
"MAX_GT_INSTANCES" : [ 250.0 ],
"MIN_CELL_SIZE_M" : [ 0.1 ],
"PRIORITIZE_LABELS" : [ 0.0 ],
"SCORE_THRESHOLD" : [ 0.2 ],
"STRIDE_FRACTION" : [ 0.5 ],
"VERSION" : [ 2.0241021E7 ]
"description" : "Test RCNN to detect to detect blue, gray and dark solar\n\t\t\tpanels panels, trained on data from Dutch Neighborhoods. Model is\n\t\t\tstill under heavy development.",
"id" : 0,
"legendEntries" : [ {
"color" : {
"argb" : 0
"entryName" : "Background",
"id" : 0,
"value" : 0.0
"color" : {
"argb" : -16711681
"entryName" : "Blue solor panel",
"id" : 1,
"value" : 1.0
"color" : {
"argb" : -3355444
"entryName" : "Gray solor panel",
"id" : 2,
"value" : 2.0
"color" : {
"argb" : -13434829
"entryName" : "Black solar panel",
"id" : 3,
"value" : 3.0
"name" : "test_solar_panels",
"override" : false,
"producer" : "Tygron",
"tensors" : [ {
"dimensions" : [ 1, 3, 600, 600 ],
"input" : true,
"name" : "input_A:RGB_normalized",
"normalize" : true,
"type" : "FLOAT"
"dimensions" : [ -1, 4 ],
"input" : false,
"name" : "boxes",
"normalize" : true,
"type" : "FLOAT"
"dimensions" : [ -1 ],
"input" : false,
"name" : "labels",
"normalize" : true,
"type" : "INT64"
"input" : false,
"name" : "scores",
"normalize" : true,
"type" : "FLOAT"
"dimensions" : [ -1, 1, -1, -1 ],
"input" : false,
"name" : "masks",
"normalize" : true,
"type" : "FLOAT"
"uploadDate" : 1734698290534,
"uploaderName" : "Tygron",
"version" : 3,
"warnings" : ""
"attributes" : {
"MASK_THRESHOLD" : [ 0.3 ],
"MAX_CELL_SIZE_M" : [ 0.5 ],
"VERSION" : [ 2.0241111E7 ]
"description" : "Test RCNN to detect decideous trees, trained on data from\n\t\t\tDutch Neighborhoods. This model is not suitable for dense woods.",
"id" : 1,
"color" : {
"argb" : 0
"id" : 0,
"value" : 0.0
"color" : {
"argb" : -16711745
"entryName" : "Decideous tree",
"id" : 1,
"value" : 1.0
"name" : "test_deciduous_trees",
"override" : false,
"tensors" : [ {
"dimensions" : [ 1, 3, 400, 400 ],
"input" : true,
"normalize" : true,
"type" : "FLOAT"
"input" : false,
"name" : "boxes",
"normalize" : true,
"type" : "FLOAT"
"input" : false,
"name" : "labels",
"normalize" : true,
"type" : "INT64"
"input" : false,
"name" : "scores",
"normalize" : true,
"type" : "FLOAT"
"input" : false,
"name" : "masks",
"normalize" : true,
"type" : "FLOAT"
"uploadDate" : 1734697444307,
"version" : 2,
"warnings" : ""
} ]Limit Queries
version=100:
https://engine.tygron.com/api/session/items/neuralnetworks/?version=100&token=API_TOKENShow Queries
max version:
https://engine.tygron.com/api/session/items/neuralnetworks/version/?token=API_TOKENsize:
https://engine.tygron.com/api/session/items/neuralnetworks/size/?token=API_TOKENFormats
HTML:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=HTML&token=API_TOKENJSON:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=JSON&token=API_TOKENCSV:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=CSV&token=API_TOKENSSV:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=SSV&token=API_TOKENSMILE:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=SMILE&token=API_TOKENZIPJSON:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=ZIPJSON&token=API_TOKENZIPSMILE:
https://engine.tygron.com/api/session/items/neuralnetworks/?f=ZIPSMILE&token=API_TOKENApi Model DataType
API Enumeration description of DataType
| Name | Description |
| FLOAT | |
| DOUBLE | |
| INT8 | |
| INT16 | |
| INT32 | |
| INT64 | |
| BOOL | |
| STRING | |
| UINT8 | |
| FLOAT16 | |
| BFLOAT16 | |
| UNKNOWN |
Api Model DefaultNeuralNetwork
API Model description of DefaultNeuralNetwork
| Name | Type | Description |
| attributes | Map<String,double[]> | |
| description | String | |
| id | int | |
| legendEntries | LegendEntry[] | |
| name | String | |
| override | boolean | |
| producer | String | |
| tensors | Tensor[] | |
| uploadDate | long | |
| uploaderName | String | |
| version | int | |
| warnings | String |
Api Model LegendEntry
API Model description of LegendEntry
| color | TColor | Color |
| entryName | String | |
| id | int | |
| value | float |
Api Model NeuralNetwork
API Model description of NeuralNetwork
| id | int | |
| name | String | |
| version | int | |
| warnings | String |
Api Model TColor
API Model description of TColor
Api Model Tensor
API Model description of Tensor
| dimensions | int[] | |
| input | boolean | |
| name | String | |
| normalize | boolean | |
| type | DataType |
