Api session items areas
API Endpoint: /api/session/items/areas/
Edit items with events described at Api session event editor area.
Default Query:
https://engine.tygron.com/api/session/items/areas/?f=JSON&token=API_TOKEN
Example Response:
  "attributes" : {
    "ACTIVE" : [ 1.0 ],
    "COLOR" : [ -6642027.0 ]
  "center" : {
    "type" : "Point",
    "coordinates" : [ 658758.7539618125, 6799054.6042297175, 44.792 ]
  "id" : 0,
  "maquetteOverride" : null,
  "name" : "Area",
  "polygons" : {
    "type" : "MultiPolygon",
    "coordinates" : [ [ [ [ 658853.0042034745, 6799058.615645016 ], [ 658851.9842460075, 6799066.578391472 ], [ 658850.2918961977, 6799074.429085737 ], [ 658847.94177127, 6799082.106013204 ], [ 658844.9468643129, 6799089.557203418 ], [ 658841.3331615041, 6799096.724189491 ], [ 658837.1234007488, 6799103.561496871 ], [ 658832.3484406329, 6799110.015530561 ], [ 658827.0440121504, 6799116.042439843 ], [ 658821.2474704315, 6799121.598373932 ], [ 658815.0010430146, 6799126.642730138 ], [ 658808.346957438, 6799131.138153902 ], [ 658801.3388101931, 6799135.053786966 ], [ 658794.0220770903, 6799138.36039521 ], [ 658786.4519787569, 6799141.035240881 ], [ 658778.6821116839, 6799143.058834491 ], [ 658770.7676964987, 6799144.414934827 ], [ 658762.7672021004, 6799145.0970452605 ], [ 658754.7390973885, 6799145.0970452605 ], [ 658746.7386029902, 6799144.414934827 ], [ 658738.8241878048, 6799143.058834491 ], [ 658731.0543207319, 6799141.035240881 ], [ 658723.4842223984, 6799138.36039521 ], [ 658716.1674892956, 6799135.053786966 ], [ 658709.1577179146, 6799131.139777972 ], [ 658702.5068806102, 6799126.642730138 ], [ 658696.2588290572, 6799121.598373932 ], [ 658690.4622873383, 6799116.042439843 ], [ 658685.1578588558, 6799110.015530561 ], [ 658680.3828987399, 6799103.561496871 ], [ 658676.1731379846, 6799096.724189491 ], [ 658672.5594351758, 6799089.555579355 ], [ 658669.5661523548, 6799082.106013204 ], [ 658667.214403291, 6799074.429085737 ], [ 658665.5220534812, 6799066.580015526 ], [ 658664.5020960142, 6799058.615645016 ], [ 658664.1626515706, 6799050.59444046 ], [ 658664.5020960142, 6799042.573243854 ], [ 658665.5220534812, 6799034.61052101 ], [ 658667.214403291, 6799026.76148941 ], [ 658669.5661523548, 6799019.0846144315 ], [ 658672.5594351758, 6799011.635113136 ], [ 658676.1731379846, 6799004.464954313 ], [ 658680.3828987399, 6798997.629354677 ], [ 658685.1578588558, 6798991.173786552 ], [ 658690.4622873383, 6798985.14697024 ], [ 658696.2588290572, 6798979.591129807 ], [ 658702.5068806102, 6798974.548489276 ], [ 658709.1577179146, 6798970.051528442 ], [ 658716.1674892956, 6798966.135975195 ], [ 658723.4842223984, 6798962.829437302 ], [ 658731.0543207319, 6798960.154650514 ], [ 658738.8241878048, 6798958.132726663 ], [ 658746.7386029902, 6798956.775033504 ], [ 658754.7390973885, 6798956.09456297 ], [ 658762.7672021004, 6798956.09456297 ], [ 658770.7676964987, 6798956.775033504 ], [ 658778.6821116839, 6798958.132726663 ], [ 658786.4519787569, 6798960.154650514 ], [ 658794.0220770903, 6798962.829437302 ], [ 658801.3388101931, 6798966.135975195 ], [ 658808.3485815742, 6798970.049904404 ], [ 658815.0010430146, 6798974.548489276 ], [ 658821.2474704315, 6798979.591129807 ], [ 658827.0440121504, 6798985.14697024 ], [ 658832.3484406329, 6798991.173786552 ], [ 658837.1234007488, 6798997.629354677 ], [ 658841.3331615041, 6799004.464954313 ], [ 658844.9468643129, 6799011.633489088 ], [ 658847.94177127, 6799019.0846144315 ], [ 658850.2918961977, 6799026.76148941 ], [ 658851.9842460075, 6799034.61052101 ], [ 658853.0042034745, 6799042.573243854 ], [ 658853.3452720542, 6799050.59444046 ], [ 658853.0042034745, 6799058.615645016 ] ] ] ]
  "relations" : null,
  "sourceIDs" : [ 1000001 ],
  "version" : 1
  "attributes" : {
    "ACTIVE" : [ 1.0 ],
    "COLOR" : [ -1.1156189E7 ],
    "OOPIE" : [ 94.0 ]
  "center" : {
    "type" : "Point",
    "coordinates" : [ 659054.0836208455, 6798899.024563928, 40.502 ]
  "id" : 1,
  "name" : "Area (2)",
  "polygons" : {
    "coordinates" : [ [ [ [ 659143.4549576816, 6798911.089440973 ], [ 659142.3732830432, 6798919.068282583 ], [ 659140.5818609316, 6798926.917209755 ], [ 659138.0936844358, 6798934.572884931 ], [ 659134.929867325, 6798941.976842419 ], [ 659131.1147716406, 6798949.067368267 ], [ 659126.6792559683, 6798955.7859964 ], [ 659121.6590513022, 6798962.080756758 ], [ 659116.0947610447, 6798967.899679161 ], [ 659110.0302368703, 6798973.197289515 ], [ 659103.5174511339, 6798977.929737752 ], [ 659096.6051279185, 6798982.0596699575 ], [ 659089.3501119873, 6798985.552980365 ], [ 659081.8124963758, 6798988.382059442 ], [ 659074.0507499833, 6798990.524169922 ], [ 659066.1282141175, 6798991.961446793 ], [ 659058.1098542222, 6798992.682521388 ], [ 659050.0573874689, 6798992.682521388 ], [ 659042.0374034374, 6798991.961446793 ], [ 659034.1181158439, 6798990.524169922 ], [ 659026.3547453153, 6798988.382059442 ], [ 659018.8155055676, 6798985.552980365 ], [ 659011.5621137725, 6798982.0596699575 ], [ 659004.6497905571, 6798977.929737752 ], [ 658998.1353806846, 6798973.197289515 ], [ 658992.0708565102, 6798967.899679161 ], [ 658986.5081903888, 6798962.080756758 ], [ 658981.4879857227, 6798955.7859964 ], [ 658977.0524700504, 6798949.067368267 ], [ 658973.2373743659, 6798941.976842419 ], [ 658970.071933119, 6798934.572884931 ], [ 658967.5837566232, 6798926.917209755 ], [ 658965.7923345118, 6798919.066658555 ], [ 658964.7122840093, 6798911.089440973 ], [ 658964.3501016604, 6798903.045646268 ], [ 658964.7122840093, 6798895.003483584 ], [ 658965.7923345118, 6798887.024665694 ], [ 658967.5837566232, 6798879.175777204 ], [ 658970.071933119, 6798871.518530398 ], [ 658973.2373743659, 6798864.114637359 ], [ 658977.0524700504, 6798857.025809942 ], [ 658981.4879857227, 6798850.30563976 ], [ 658986.5081903888, 6798844.010966325 ], [ 658992.0708565102, 6798838.192132981 ], [ 658998.1353806846, 6798832.8946109805 ], [ 659004.6497905571, 6798828.162247533 ], [ 659011.5621137725, 6798824.034017855 ], [ 659018.8155055676, 6798820.540777152 ], [ 659026.3547453153, 6798817.71175673 ], [ 659034.1181158439, 6798815.569691985 ], [ 659042.0374034374, 6798814.132446433 ], [ 659050.0573874689, 6798813.409763738 ], [ 659058.1098542222, 6798813.409763738 ], [ 659066.1282141175, 6798814.132446433 ], [ 659074.0507499833, 6798815.569691985 ], [ 659081.8124963758, 6798817.71175673 ], [ 659089.3501119873, 6798820.540777152 ], [ 659096.6051279185, 6798824.034017855 ], [ 659103.5174511339, 6798828.162247533 ], [ 659110.0302368703, 6798832.8946109805 ], [ 659116.0947610447, 6798838.192132981 ], [ 659121.6590513022, 6798844.010966325 ], [ 659126.6792559683, 6798850.30563976 ], [ 659131.1147716406, 6798857.025809942 ], [ 659134.929867325, 6798864.113013343 ], [ 659138.0936844358, 6798871.518530398 ], [ 659140.5818609316, 6798879.175777204 ], [ 659142.3732830432, 6798887.024665694 ], [ 659143.4549576816, 6798895.003483584 ], [ 659143.8155158944, 6798903.045646268 ], [ 659143.4549576816, 6798911.089440973 ] ] ] ]
  "relations" : null,
  "version" : 3
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/areas/?version=100&token=API_TOKEN
Pseudo-Mercator:
https://engine.tygron.com/api/session/items/areas/?crs=3857&token=API_TOKEN
Degrees:
https://engine.tygron.com/api/session/items/areas/?crs=4326&token=API_TOKEN
Amersfoort / RD New:
https://engine.tygron.com/api/session/items/areas/?crs=28992&token=API_TOKEN
Local Coordinates:
https://engine.tygron.com/api/session/items/areas/?crs=LOCAL&token=API_TOKEN
bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785:
https://engine.tygron.com/api/session/items/areas/?crs=3857&bbox=658636.7618515313,6798649.869141218,659042.7958749933,6799055.882798785&token=API_TOKEN
FOO:
https://engine.tygron.com/api/session/items/areas-foo/?crs=3857&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/areas/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/areas/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/areas/?f=HTML&token=API_TOKEN
JSON:
GEOJSON:
https://engine.tygron.com/api/session/items/areas/?f=GEOJSON&token=API_TOKEN
GPKG:
https://engine.tygron.com/api/session/items/areas/?f=GPKG&token=API_TOKEN
DXF:
https://engine.tygron.com/api/session/items/areas/?f=DXF&token=API_TOKEN
CSV:
https://engine.tygron.com/api/session/items/areas/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/areas/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/areas/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/areas/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/areas/?f=ZIPSMILE&token=API_TOKEN
Api Model Area
API Model description of Area
Name Type Description
attributes Map<String,double[]>
center Point Point
id int
maquetteOverride Map<String,double[]>
name String
polygons MultiPolygon MultiPolygon
relations Map<Relation,int> Map<Relation,int>
sourceIDs int[] [[Source]]s ID
version int
Api Model GeometryCollection
API Model description of GeometryCollection
Api Model MultiPolygon
API Model description of MultiPolygon
type String [[#Api Model MultiPolygon|MultiPolygon]]
coordinates double[][][][] array of [[#Api Model Polygon|Polygon]]s; [[#Api Model Polygon|Polygon]] is array of outer and optional inner rings; rings is array of coordinates; coordinates is array of [x,y,(optional) z]
Api Model Point
API Model description of Point
type String [[#Api Model Point|Point]]
coordinates double[] x, y, (optional) z
Api Model Relation
API Enumeration description of Relation
Name Description
OWNER
CONSTRUCTOR
DEMOLISHER
PERMITTER
SENDER
RECEIVER
NETOWNER
BORDER_A
BORDER_B
BUILDING
WEATHER
PARENT
RESULT_PARENT
CONTENT
