Web Endpoint
General path: web/
Web
getKeepAlive
Path: web/resettimeout
Type: GET
Produces: text/plain
Parameters: None
get3DMap
Path: web/{a:3dmap.html|cesium.html}
Type: GET
Produces: text/html
Parameters:
| Name | Location | Type | Default value |
| webStakeholderID | Header | Integer | |
| overlay | Query | Integer | |
| base | Query | WebBaseMap | |
| style | Query | WebModelStyle | |
| shadow | Query | Boolean | |
| texture | Query | TextureSize | |
| spacing | Query | Double |
getAssets
Path: web/assets/{path : [a-zA-Z0-9/._-]+}
Type: GET
Produces: image/png , image/jpeg
Parameters:
| path | Path | String |
getDomainLogo
Path: web/domain.png
Type: GET
Produces: image/png
Parameters: None
getCSS
Path: web/{name}.css
Type: GET
Produces: text/css
Parameters:
| name | Path | String | |
| replacetoken | Query | boolean | true |
get2DMap
Path: web/{a:2dmap.html|map.html}
Type: GET
Produces: text/html
Parameters:
getLibJS
Path: web/{name}.js
Type: GET
Parameters:
getPanel
Path: web/{path:|index.html|panel.html|panel.body}
Type: GET
Produces: text/html
Parameters:
| stakeholderid | Query | Integer | -1 |
| path | Path | String | |
| css | Query | Boolean |
postEventForm
Path: web/event/{eventclass}/{eventname}
Type: POST
Parameters:
| eventclass | Path | String | |
| eventname | Path | String |
ActionMenu
getActionMenuActions
Path: web/actionmenuactions.geojson
Type: GET
Produces: application/json
Parameters:
| crs | Query | String | EPSG:3857 |
getActionMenus
Path: web/actionmenus.geojson
Type: GET
Parameters:
getCinematic
Path: web/cinematic.geojson
Type: GET
Parameters:
| forcexy | Query | Boolean | |
getMeasure
Path: web/measure.geojson
Type: GET
Parameters:
Indicator
getIndicator
Path: web/indicator.html
Type: GET
Produces: text/html
Parameters:
| css | Query | boolean | true |
| maptype | Query | Map Type | MAQUETTE |
getIndicators
Path: web/indicators.geojson
Type: GET
Parameters:
Label
getNeighborhoods
Path: web/neighborhoods.geojson
Type: GET
Parameters:
getStreets
Path: web/streets.geojson
Type: GET
Parameters:
Map
getDirection
Path: web/direction.{format}
Type: GET
Parameters:
| format | Path | String | |
| id | Query | Integer | |
| width | Query | int | 256 |
| height | Query | int | 256 |
| timeframe | Query | int | 0 |
| xy | Query | boolean | 0 |
getFlood
Path: web/flood.{format}
Type: GET
Parameters:
| offset | Query | float | 0 |
| worlddatum | Query | boolean | false |
| decimation | Query | int | 16 |
getTerrain
Path: web/terrain.{format}
Type: GET
Parameters:
| bbox | Query | String | |
getTerrainTile
Path: web/terrain/{z}/{x}/{y}.{format}
Type: GET
Parameters:
| z | Path | int | |
| x | Path | int | |
| y | Path | int | |
| v | Query | String | |
getWater
Path: web/water.{format}
Type: GET
Parameters:
| flipY | Query | boolean | false |
getWMS
Path: web/wms
Type: GET
Parameters:
| request | Query | Request | GetCapabilities |
| layers | Query | String | |
| layer | Query | String | |
| x | Query | int | -1 |
| y | Query | int | -1 |
| i | Query | int | -1 |
| j | Query | int | -1 |
| bgcolor | Query | String | |
| format | Query | String | |
| info_format | Query | String | text/plain |
| walled | Query | boolean | true |
| styles | Query | String |
postAvgHeight
Path: web/avgheight.number
Type: POST
Produces: application/json , application/octet-stream
Parameters:
| f | Query | Format | JSON |
| buildings | Query | boolean | false |
Net
getLines
Path: web/lines.geojson
Type: GET
Parameters:
| minlength | Query | Double | |
| maxlength | Query | Double | |
| type | Query | Net Type | |
Overlay
getOverlays
Path: web/overlays.geojson
Type: GET
Parameters:
getOverlayImage
Path: web/overlay.png
Type: GET
Parameters:
Popup
getPopup
Path: web/popup.html
Type: GET
Produces: text/html
Parameters:
getPopupClusters
Path: web/popupclusters.geojson
Type: GET
Parameters:
getPopups
Path: web/popups.geojson
Type: GET
Parameters:
Scenario
getScenarios
Path: web/scenarios.geojson
Type: GET
Parameters:
Version
getVersion
Path: web/version.json
Type: GET
Parameters:
| links | Query | String |
getItemVersion
Path: web/itemversion.json
Type: GET
Parameters:
| link | Query | String | |
| itemid | Query | String |
