Api session event participant money transfer give
API Endpoint: api/session/event/participant/money_transfer_give/
Description: Give money from one Stakeholder to another.
0 REQUIRED (STAKEHOLDER Integer ID) Initiating Stakeholder ID
1 REQUIRED (STAKEHOLDER Integer ID) Money receiving Stakeholder ID
2 REQUIRED (Enumeration) Type of transfer LAND, SUBSIDY or TRANSFER
3 REQUIRED (String) Message text
4 REQUIRED (Floating point number) Amount
204 No Content
curl 'https://engine.tygron.com/api/session/event/participant/money_transfer_give/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Message text", 81 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/participant/money_transfer_give/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Message text", 29 ]'
JavaScript example POST:
 body: '[ 1, 1, "SUBSIDY", "Message text", 81 ]'
fetch("https://engine.tygron.com/api/session/event/participant/money_transfer_give/", options)
