Api session event logic set traffic multiplier
API Endpoint: api/session/event/logic/set_traffic_multiplier/
Description: Multiply visual (only) traffic density with this factor.
| 0 | REQUIRED | (Floating point number) | Factor, default 4.0 |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '14'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '24'JavaScript example POST:
body: '14'
fetch("https://engine.tygron.com/api/session/event/logic/set_traffic_multiplier/", options)
