Api session event logic net cluster set fraction connected
API Endpoint: api/session/event/logic/net_cluster_set_fraction_connected/
Description: Set the frAction of connected loads with a cluster.
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster ID
1 REQUIRED (Floating point number) FrAction connected, between 0 and 1
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 55 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 6 ]'
JavaScript example POST:
 body: '[ 1, 55 ]'
fetch("https://engine.tygron.com/api/session/event/logic/net_cluster_set_fraction_connected/", options)
