Api session event logic money transfer add
API Endpoint: api/session/event/logic/money_transfer_add/
Description: Create a new Money Transfer between two Stakeholders.
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder From ID
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder To ID
2 REQUIRED (Enumeration) Money Transfer Type LAND, SUBSIDY or TRANSFER
3 REQUIRED (String) Provided motivation
4 REQUIRED (Floating point number) Transfer amount
204 No Content
curl 'https://engine.tygron.com/api/session/event/logic/money_transfer_add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Provided motivation", 49 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/money_transfer_add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, "SUBSIDY", "Provided motivation", 10 ]'
JavaScript example POST:
 body: '[ 1, 1, "SUBSIDY", "Provided motivation", 49 ]'
fetch("https://engine.tygron.com/api/session/event/logic/money_transfer_add/", options)
