Api session event logic building set attribute
API Endpoint: api/session/event/logic/building_set_attribute/
Description: Set Building Attribute to given number Value.
| 0 | REQUIRED | (BUILDING Integer ID) | Building ID | |
| 1 | REQUIRED | (String) | Attribute Name | |
| 2 | REQUIRED | (Floating point number) | Value |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 79 ]'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/logic/building_set_attribute/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, "Attribute Name", 24 ]'JavaScript example POST:
body: '[ 1, "Attribute Name", 79 ]'
fetch("https://engine.tygron.com/api/session/event/logic/building_set_attribute/", options)
