Api session event editor time set start date
API Endpoint: api/session/event/editortime/set_start_date/
Description: Set Start Date
| 0 | REQUIRED | (Integer number) | Long |
| 204 | No Content |
curl 'https://engine.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '18'Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editortime/set_start_date/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '12'JavaScript example POST:
body: '18'
fetch("https://engine.tygron.com/api/session/event/editortime/set_start_date/", options)
