Api session event editor stakeholder add
API Endpoint: api/session/event/editorstakeholder/add/
Description: Add new Stakeholder
200 Integer (Integer)
curl 'https://engine.tygron.com/api/session/event/editorstakeholder/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''
JavaScript example POST:
 body: ''
fetch("https://engine.tygron.com/api/session/event/editorstakeholder/add/", options)
