Api session event editor overlay set tensor normalized
API Endpoint: api/session/event/editoroverlay/set_tensor_normalized/
Description: Set whether an input tensor of an Inference Overlay should be normalized when provided to a Neural Network.
0 REQUIRED (OVERLAY Integer ID) Inference Overlay ID
1 REQUIRED (Integer number) Tensor Link ID
2 REQUIRED (true, false) Normalize true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_normalized/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, true ]'
JavaScript example POST:
 body: '[ 1, 1, true ]'
fetch("https://engine.tygron.com/api/session/event/editoroverlay/set_tensor_normalized/", options)
