Api session event editor netsetting set boolean
API Endpoint: api/session/event/editornetsetting/set_boolean/
Description: Set Boolean
0 REQUIRED (Enumeration) Type CLUSTER_FRACTION_CONNECTED, CLUSTER_MODELS_ENABLED, ELECTRICITY_ACTIVE, ELECTRICITY_FLOW_ATTRIBUTE, ELECTRICITY_NETWORK_OWNER_ID, FIRST_CONNECT_ACCEPT, GAS_ACTIVE, GAS_FLOW_ATTRIBUTE, GAS_NETWORK_OWNER_ID, HEAT_ACTIVE, HEAT_FLOW_ATTRIBUTE, HEAT_NETWORK_OWNER_ID, INTERNET_ACTIVE, INTERNET_FLOW_ATTRIBUTE, INTERNET_NETWORK_OWNER_ID, LOAD_TO_NODE_LINES_ENABLED, REQUIRE_UTILITY_CORPORATION_APPROVAL, RESTRICT_TO_NET_OVERLAY, SEWER_ACTIVE, SEWER_FLOW_ATTRIBUTE or SEWER_NETWORK_OWNER_ID
1 REQUIRED (true, false) Boolean true or false
204 No Content
curl 'https://engine.tygron.com/api/session/event/editornetsetting/set_boolean/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ "CLUSTER_FRACTION_CONNECTED", true ]'
JavaScript example POST:
 body: '[ "CLUSTER_FRACTION_CONNECTED", true ]'
fetch("https://engine.tygron.com/api/session/event/editornetsetting/set_boolean/", options)
