Api session event editor netcluster add
API Endpoint: api/session/event/editornetcluster/add/
Description: Add new Net Cluster
| 200 | Integer (Integer) |
curl 'https://engine.tygron.com/api/session/event/editornetcluster/add/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d ''JavaScript example POST:
body: ''
fetch("https://engine.tygron.com/api/session/event/editornetcluster/add/", options)
