Api session event editor building set slanting roof height
API Endpoint: api/session/event/editorbuilding/set_slanting_roof_height/
Description: Change Height of the Slanting Roof of a Building Section
0 REQUIRED (BUILDING Integer ID) Building ID
1 REQUIRED (Integer number) Section ID
2 REQUIRED (Floating point number) Slanting roof height
204 No Content
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 87 ]'
Curl example multi item POST:
curl 'https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/' -H 'Content-Type: application/json' -H 'Authorization: Bearer API_TOKEN' -d '[ 1, 1, 51 ]'
JavaScript example POST:
 body: '[ 1, 1, 87 ]'
fetch("https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/", options)
