Web Endpoint
Revision as of 09:12, 3 June 2026 by Frank@tygron.nl (talk | contribs)
General path: web/
Web
getKeepAlive
Path: web/resettimeout
Type: GET
Produces: text/plain
Parameters: None
getCSS
Path: web/{name}.css
Type: GET
Produces: text/css
Parameters:
Name Location Type Default value
name Path String
replacetoken Query boolean true
get2DMap
Path: web/{a:2dmap.html|map.html}
Type: GET
Produces: text/html
Parameters:
webStakeholderID Header Integer
base Query WebBaseMap
get3DMap
Path: web/{a:3dmap.html|cesium.html}
Type: GET
Produces: text/html
Parameters:
overlay Query Integer
style Query WebModelStyle
shadow Query Boolean
texture Query TextureSize
spacing Query Double
getAssets
Path: web/assets/{path : [a-zA-Z0-9/._-]+}
Type: GET
Produces: image/png , image/jpeg
Parameters:
path Path String
Path: web/domain.png
Type: GET
Produces: image/png
Parameters: None
getLibJS
Path: web/{name}.js
Type: GET
Parameters:
name Path String
getPanel
Path: web/{path:|index.html|panel.html|panel.body}
Type: GET
Produces: text/html
Parameters:
stakeholderid Query Integer
path Path String
id Query Integer
css Query Boolean
postEventForm
Path: web/event/{eventclass}/{eventname}
Type: POST
Parameters:
eventclass Path String
eventname Path String
ActionMenu
getMeasure
Path: web/measure.geojson
Type: GET
Produces: application/json
Parameters:
crs Query String EPSG:3857
forcexy Query Boolean
id Query Integer
getCinematic
Path: web/cinematic.geojson
Type: GET
Parameters:
id Query Integer
getActionMenuActions
Path: web/actionmenuactions.geojson
Type: GET
Parameters:
id Query Integer
getActionMenus
Path: web/actionmenus.geojson
Type: GET
Parameters:
Indicator
getIndicator
Path: web/indicator.html
Type: GET
Produces: text/html
Parameters:
id Query Integer
css Query boolean true
maptype Query Map Type MAQUETTE
getIndicators
Path: web/indicators.geojson
Type: GET
Parameters:
Label
getNeighborhoods
Path: web/neighborhoods.geojson
Type: GET
Parameters:
getStreets
Path: web/streets.geojson
Type: GET
Parameters:
Map
getDirection
Path: web/direction.{format}
Type: GET
Parameters:
format Path String
id Query Integer
width Query int 256
height Query int 256
timeframe Query int 0
xy Query boolean 0
getFlood
Path: web/flood.{format}
Type: GET
Parameters:
format Path String
id Query Integer
width Query int 256
offset Query float 0
worlddatum Query boolean false
decimation Query int 16
getTerrain
Path: web/terrain.{format}
Type: GET
Parameters:
format Path String
bbox Query String
id Query Integer
width Query int 256
getTerrainTile
Path: web/terrain/{z}/{x}/{y}.{format}
Type: GET
Parameters:
format Path String
z Path int
x Path int
y Path int
v Query String
width Query int 256
getWater
Path: web/water.{format}
Type: GET
Parameters:
format Path String
id Query Integer
width Query int 256
flipY Query boolean false
getWMS
Path: web/wms
Type: GET
Parameters:
request Query Request GetCapabilities
bbox Query String
width Query int 256
layers Query String
layer Query String
x Query int
y Query int
i Query int
j Query int
bgcolor Query String
format Query String
info_format Query String text/plain
walled Query boolean true
styles Query String
postAvgHeight
Path: web/avgheight.number
Type: POST
Produces: application/json , application/octet-stream
Parameters:
f Query Format JSON
buildings Query boolean false
Net
getLines
Path: web/lines.geojson
Type: GET
Parameters:
bbox Query String
minlength Query Double
maxlength Query Double
type Query Net Type
Overlay
getOverlays
Path: web/overlays.geojson
Type: GET
Parameters:
getOverlayImage
Path: web/overlay.png
Type: GET
Parameters:
bbox Query String
width Query int 256
id Query Integer
format Query String
styles Query String
getPopup
Path: web/popup.html
Type: GET
Produces: text/html
Parameters:
id Query Integer
css Query Boolean
getPopupClusters
Path: web/popupclusters.geojson
Type: GET
Parameters:
bbox Query String
getPopups
Path: web/popups.geojson
Type: GET
Parameters:
bbox Query String
Scenario
getScenarios
Path: web/scenarios.geojson
Type: GET
Parameters:
Version
getVersion
Path: web/version.json
Type: GET
Parameters:
links Query String
getItemVersion
Path: web/itemversion.json
Type: GET
Parameters:
link Query String
itemid Query String
