Api Session Stream Endpoint
Revision as of 09:05, 3 June 2026 by Frank@tygron.nl (talk | contribs)
General path: api/session/stream/
SessionStream
getDoc
Path: api/session/stream/{a:|index.html}
Type: GET
Parameters: None
getExport
Path: api/session/stream/export
Type: GET
Parameters:
Name Location Type Default value
f Query Format BINARY
maplink Query Maplink
id Query Integer
postImport
Path: api/session/stream/import
Type: POST
Parameters:
id Query Integer
input Query Format BINARY
f Query Format JSON
name Query String
uploader Query String
crs Query String
