Api session items triggers
Revision as of 09:05, 3 June 2026 by Frank@tygron.nl (talk | contribs)
API Endpoint: /api/session/items/triggers/
Edit items with events described at Api session event editor trigger.
Default Query:
https://engine.tygron.com/api/session/items/triggers/?f=JSON&token=API_TOKEN
Example Response:
  "active" : true,
  "calcTimeMS" : 15,
  "id" : 1,
  "method" : "GET",
  "name" : "Before",
  "timeoutMS" : 10000,
  "timing" : "BEFORE",
  "type" : "TQL",
  "url" : "https://development.tygron.com/api/session/hello",
  "version" : 5,
  "warnings" : ""
  "active" : true,
  "calcTimeMS" : 0,
  "id" : 2,
  "method" : "GET",
  "name" : "After",
  "timing" : "AFTER",
  "type" : "TQL",
  "url" : "https://api.powerbi.com/v1.0/myorg/groups/%7BgroupId%7D/datasets/%7BdatasetId%7D/refreshes",
  "version" : 4,
  "warnings" : "Warning: "
Limit Queries
version=100:
https://engine.tygron.com/api/session/items/triggers/?version=100&token=API_TOKEN
Show Queries
max version:
https://engine.tygron.com/api/session/items/triggers/version/?token=API_TOKEN
size:
https://engine.tygron.com/api/session/items/triggers/size/?token=API_TOKEN
Formats
HTML:
https://engine.tygron.com/api/session/items/triggers/?f=HTML&token=API_TOKEN
JSON:
CSV:
https://engine.tygron.com/api/session/items/triggers/?f=CSV&token=API_TOKEN
SSV:
https://engine.tygron.com/api/session/items/triggers/?f=SSV&token=API_TOKEN
SMILE:
https://engine.tygron.com/api/session/items/triggers/?f=SMILE&token=API_TOKEN
ZIPJSON:
https://engine.tygron.com/api/session/items/triggers/?f=ZIPJSON&token=API_TOKEN
ZIPSMILE:
https://engine.tygron.com/api/session/items/triggers/?f=ZIPSMILE&token=API_TOKEN
Api Model Method
API Enumeration description of Method
Name Description
GET
POST
Api Model Timing
API Enumeration description of Timing
Name Description
BEFORE
AFTER
Api Model Trigger
API Model description of Trigger
Name Type Description
active boolean
calcTimeMS long
id int
method Method
name String
timeoutMS int
timing Timing
type Type
url String
version int
warnings String
Api Model Type (Trigger)
API Enumeration description of Type
Name Description
TQL
EVENT
